The right way to do a FPR?
95_GS_5Spd
03-11-2005, 11:22 AM
ok, I'm new here obviously. But, I need help. I blew my 95 GS the other day, so I'm working on a 96 Eagle Talon that I've had sitting around for a while. Well, the Fuel pressure regulator is dumping fuel into the alternator, so I ordered a new replacement. I was wanting to know the RIGHT way to change FPRs so that I'm ready when the part gets here. THANKS!!!!
97_3clipse
03-12-2005, 12:09 AM
its leaking?!? FPRs?!? im lost....
EDIT>>> oh fuel pressure regulator. its pretty much straight forward... un-bolt it take it off and replace with new hardware, wear some old clothes because gaurenteed you will get gas on them...
95_GS_5Spd
03-12-2005, 02:25 AM
Thanks, but I've already figured it out and have fixed the problem. There is a small snap-ring holding the pressure regulator into the fuel rail. Simply remove this, pull FPR out, lube new FPR with grease, pop it back in, and simply replace the snap-ring...Hook up the vaccuum line and Voila!...you're done...lol
kjewer1
03-12-2005, 03:27 AM
Just make sure you didnt use a grease that will break down the O-ring that I'm ASSuming the NT regulators have. ;)
Edit> The oring is probably Viton, which is safe with most materials, but its something I try to think about anyway.
