91 MR2 swapped engine & now fast idle?Autofreefindersguy 03-11-2005, 09:22 AM Hey guys, I finally picked up my new 91 MR2 na... A guy swapped out the bad engine for another 91 na engine, she runs well, but I am having a fast idle...around 2100 RPM's... Any idea's? Thanks much for any help. Autofreefindersguy 03-14-2005, 10:25 AM Update: I found the cable for the throttle was somewhat off track and its now down to 1500 RPM's...Still too high though... It seems to have very slow/sluggish response to throttle aplications until in gets up in the higher RPM's...(It has new plugs,wires & Cap & rotor) Any idea's? BlitzKeg 03-14-2005, 12:29 PM are you sure you adjusted the throttle cable to proper idle?...It makes sense that the guy that did the swap might have forgotten to adjust it. U should have a friend rev the engine while you check and adjust it just to make sure before you blow abuncha money replace good parts. hows the driveability?-I mean is it just fast idle or is it rough idle...Is there any other problems? Autofreefindersguy 03-14-2005, 12:49 PM Thanks for the reply. It runs fine/flawless at speed, but seem to have a sluggish/slow take off. Yes, perhaps the cable can be adjusted more? Automotive Network, Inc., Copyright ©2012
