blazer LS wont startpippen 03-10-2005, 11:00 PM My blazer 2000 wont start, it cranks but wont make any effort to start. i checked : -the timing = good -fire = good -fuel pressure= was not to good, i replaced the fuel pump and now is very good -power osscillation to intectors= good -fuel filter=good -distributor and rotor the sparkplugs stay dry, so i think the problem is betweene the fuel line connecting on the engine and the combustion chamber. how can i get to the fuel regulator (procedure) and what else could prevent fuel to get to the injectors. Thanks BlazerLT 03-11-2005, 02:34 AM My blazer 2000 wont start, it cranks but wont make any effort to start. i checked : -the timing = good -fire = good -fuel pressure= was not to good, i replaced the fuel pump and now is very good -power osscillation to intectors= good -fuel filter=good -distributor and rotor the sparkplugs stay dry, so i think the problem is betweene the fuel line connecting on the engine and the combustion chamber. how can i get to the fuel regulator (procedure) and what else could prevent fuel to get to the injectors. Thanks What is the fuel pressure. I don't want to hear it is good, I want to see the actual pressure measurement. ricksza 03-11-2005, 06:09 AM Fuel pump running engine off, pressure should be 414-455 kPa (60-66 psi). when the pump shuts off, it should drop 34 kPa (5 psi) and remain steady. Does it? How are you checking the injectors? blazee 03-11-2005, 09:09 AM What problems did you have before the no start condition? Any recent repairs done? Have you checked all the fuses? pippen 03-13-2005, 10:55 AM Pressure is now 65 psi (brand new AC delco pump) i did not have any problems before one morning it just did'nt start. i checked all the fuses, and the injectors are getting there negative ocillations from the ECM. ricksza 03-13-2005, 02:24 PM Did you check for spark? pippen 03-13-2005, 02:43 PM fire and timming is good BlazerLT 03-13-2005, 02:59 PM fire and timming is good The security system might have disabled the trucks ignition. CPO-97Blazer 03-13-2005, 10:26 PM Just had to replace my fuel pressure regulator in my 97 blazer. Ran just over 500 smackaroos. However, no more problems with it taking 15 secs to turn over. When I finally took it in to get fixed, took almost 1 minute before starting, then had a big shake which I figure was only a few of the cylinders getting fuel. BlazerLT 03-13-2005, 11:52 PM 500 for a FPR? You got screwed bro. pippen 03-14-2005, 09:39 AM If the security system was bloking ignition would i still have gas presure, fire and ingector signal....? ricksza 03-14-2005, 08:06 PM Security System disables the injectors. pippen 03-14-2005, 08:56 PM i have ingector signal pippen 03-21-2005, 05:57 PM the injection spider was stuck i changed it and iAm all set now. also changed the filter. Automotive Network, Inc., Copyright ©2012
