vsscywilliams 03-09-2005, 02:15 PM i replace my vss and my trottle position sensor and my check engine light keep coming on after i had it removed i was told that these are the things i should replace in order to pass emission dksob81 03-09-2005, 02:23 PM what year is the vehicle? Have you had the Codes checked to see what they are? cywilliams 03-09-2005, 02:46 PM it is a 1998 and these are the 2 problem that the scan came up with. dksob81 03-09-2005, 03:00 PM what were the codes? cywilliams 03-09-2005, 03:11 PM eng: 26/p0122 tps voltage low eng: 166/p0720 output speed sensor circuit xj31 03-09-2005, 11:38 PM output speed sensor is not the same as the vss.the output speed sensor is in the trans and the vehicle speed sensor is the one in the t case cywilliams 03-10-2005, 08:16 AM thanks for the info i kind of thought it was different. Automotive Network, Inc., Copyright ©2012
