How many miles do you have your Isuzu?
Pages : 1 2 3 4 5 [6]
jggaffney
10-18-2010, 11:46 AM
2000 Passport EX 4WD
120k miles
Replaced shift indicator switch and intermittent wiper relay board.
This truck gets all regular service.
al.
10-20-2010, 02:47 PM
2000 Rodeo LS 4x4 - bought it in 2001 with about 9k miles.
257,000 miles
repairs:
brakes, tires, batteries, timing belts, serpentine belts, etc. as expected.
fuel sending unit
starter
alternator
transmission range sensor
transmission
Klownicle
12-06-2010, 10:45 AM
1999 Honda Passport EX
http://www.cardomain.com/ride/2982219/1999-honda-passport
166K, still running nicely with normal repair.
Replaced; Radiator, Fuel Pump, Transmission, Range Mode Sensor, Alternator, Fuel Sending Unit, Idler Pully, Fan Clutch w/ New OEM Fan, 4 O2 Sensors, AC Compressor w/ Clutch, Headlights (original were yellowed), Change Oil Every 3000miles, Starter, Belt's, Filters, Breaks, Rotors, Spark Plugs, Clean EGR Valve, & try to keep up with Regular service.
To Come?; Joints, Body, Bearings, Rear-end Front-end... hope non of this soon. I do have a knock when the body twists in the cold. Only seems to happen during our Florida winters.
Truck is actually for sale, I'm a younger guy and want somthing newer as my own choice. Purchased this vehicle as a quick need a truck. Been a great vehicle but want somthing new. But I don't know. Feel the need for a change after 7 years.
Contact me if interested. :runaround: Make me a Offer! Highly Customized.
isuzu95
01-03-2011, 11:09 PM
254,000
labrea
02-11-2011, 10:05 AM
2001 Isuzu Rodeo LS 2WD Auto
Just bought it few days ago with 121k mileage
problems:
front shocks need to be replaced
i can hear whistle from somewhere i need to find it
17mpg
Let me update it after 9 months.
Replaced:
Transmission filter and fluid,
Lubricate drive shaft
Manifold gasket,
A/C Compressor (broke down again after 5k miles)
Drive Shaft Support bracket broke while driving, found one from junkyard and replaced.
Transmission fluid blow out, servo cover replaced and new fluid.
Well, now car has 132k mileage on it.
Here is the servo cover, new one is on the left, bad is right
http://i.imgur.com/lL2au.jpg
longbeachMartin
03-16-2011, 01:24 PM
150000
nasolovesyou
01-01-2012, 10:56 AM
Just picked up a '97 Rodeo LS with 72k miles, in great condition! So excited
sdsisuzu
01-03-2012, 08:53 AM
Replaced:
Manifold gasket,
Did you track down your whistle? I have the same sound on my 95.5 with 100,000 miles. Just bought it so I don't have much for maintenance records.
Hauler
01-19-2012, 09:44 AM
'94 Rodeo 279,000. No problems, but general stuff--timing belt, clutch, brakes, and such. Taking it across the country again this month.
cubigman
02-19-2012, 04:21 PM
93 rodeo, V6 3.2L,
3 inch calmini lift
325,000 miles and still going
godwinsm
02-28-2012, 01:21 PM
1994
3.2L v6
228,500
lets see...
various hoses replaced, molded and otherwise
timing belt snapped on freeway,
back doors dont open,
replaced all major gaskets,
needs new rings,
am replacing idler arms, just preventative, mind you.
leaks rainwater into the driver floorpan
significant wind whistle.
i just love the darn thing. bought it for 1500 bucks 75000 miles ago and never looked back.
kenc195
06-04-2012, 05:40 PM
1997 3.6L 270,000. Normal stuff but I have gone through 2 harmonic dampners
sdsisuzu
06-05-2012, 01:19 PM
1995.5 Isuzu Rodeo 103,000 miles. 5 spd, 3.2 engine
I bought this with 97,000 miles on it. Someone drove it the other day and said the clutch is almost shot because the pedal comes up about halfway or so before it engages.
I don't have any service records but it seems to shift OK. I'm used to a honda civic with a cable tranny so this hydro clutch is a little different for me.
Does the amount of clutch pedal travel that I have mean the clutch is on it's way out?
Anyone know the cost of replacing one of these?
Thanks for the input!
todaugen
07-08-2012, 01:45 PM
I just bought a 95.5 manual and the clutch comes up pretty high before engaging. It catches strong, though, and is not slipping, so I am going to wait to replace it.
I called the local shop I like using and they said the book price was $1400, which seems ridiculous to me, but the mechanic did say it would probably be less--how much less he couldn't say :shakehead I was expecting something in the $700 range.
If your truck isn't juttering badly upon moving from a stand still, and there is no clutch slippage, I would drive it as is. You may get another handful of problem free years out of the current clutch.
(FYI--95.5 rodeo 137K and running strong. This truck replaces a 99 Tacoma that was recalled do to frame rust, and it's a worthy machine.)
tonyvj
09-16-2012, 01:20 AM
put new key in door now need to reset alarm code help
WhiteRodeo4x4
11-18-2012, 12:26 AM
2001 Rodeo V-6 Auto. Just bought the car with 116018 miles. Frame was undercoated from day 1 so there ids no rust. Only problem I have so far is the #6 coil pack was on the wrong cylinder and was getting a P0300 code,and just found out that the front 4x4 actuator is either not working or the connectors are dirty. Car runs good and hasn't been beat to the ground. Original owner is from Vermont and traded car in at a Westboro Mass Dealership.
dingobait
12-02-2012, 05:24 PM
Year: 1999
Engine: 3.2L V6
Mileage:252,000
Any major problems: No
M15TAK3N
02-17-2014, 06:56 PM
1995
3.2
V6
111k
front rotors warped, rocker shafts and arms are ticking, routine maint other than that
kmoore74
04-24-2014, 11:39 AM
Year: 2001
Engine: 2.2L 4-Cyl.
Mileage: 161,000
Any major problems: No, other than I can't seem to determine why it's recently began idling rough and I can smell gas/exhaust fumes when it's idling. I've replaced the fuel filter, fuel pressure regulator, plugs, wires, and I've ran Seafoam through the throttle body via vacuum hose, in through the gas tank.
Miner2
09-03-2014, 01:09 AM
2000 rodeo 3.2 2wd 187000 miles
I have had this SUV for approx. 1 1/2 yrs.
Rebuilt tyranny, changed timing belt, TPS, fuel tank level sensor, shocks, and getting ready to replace seal on ac compressor. I like the power of this 3.2 and now the tranny shifts correctly. Nice car.:)
chritophur
08-09-2015, 02:21 PM
93 amigo xs 2wd
2.6L, manual trans,
ac, sun roof, hard top, trailer hitch
325,000 miles
15"Michellins, aluminum rims =125k mi per set
I keep getting rear ended by women that "want to get to know me". Just wish they would realize I like my Isuzu more than any body, save me the hassle, and just give me money like all the other women.:uhoh:
datphilthy1
09-10-2015, 05:22 PM
Year: 1999
Engine: 3.2L V6
Mileage: 326207
Any major problems: None
I bought it reluctantly brand new with only 40 miles on it. I had just started a new job (which turned out to be my career), college and my son was 3 at the time. My dad told me I should get a more reliable vehicle and he picked it out and said he would help with the down payment if I got it. I hated it. Did not want a stick shift although I did want an SUV. So I bought it.
It turned out to be the best purchase of my life. Watched my son grow up from his car seat to the driver seat in Her, and She carried my second son home from the hospital when he was born in 06.
I kept Her up pretty faithfully with my oil changes and tune ups. I have to do a better job with flushing and replacing coolant and transmission fluids; I have done that at about 2x. But NO MAJOR PROBLEMS. Just got a new catalytic converter in 2013 costed me $600 just to pass smog. Other than that I did most of the work myself starter 2x, alternator once, fuel pump, and brakes once (just the front never had to do the back ones yet). Also had the AC compressor replaced a couple times, after this summer it may need it again.
I have used her as a commuter from Sacramento to the SF bay area for 6 years. She is still my commuter but now I only work 30 miles away from home.
Thought She was a goner a few days ago; all of a sudden She started smoking on my way to work and heard noise coming from the engine. I was sad. But turned out to be a broken Idler pulley. Got her back on the road the next day. She is still going strong, feels like I can get another 300k miles out of Her!
sdpassport
09-26-2015, 10:48 AM
After a long hiatus after selling my 95 Passport I am back with a 1995 Isuzu Rodeo with 174K.
Interior is pretty clean but the engine leaks oil so I have some work to do.
