what plugs are you using?
for a compression test, remove the spark plugs, disable fuel injectiors(pull the fuse), screw in the tester. make sure the tester is reset to zero, crank the engine for ten compression strokes(with the tester in, the compression stroke will sound more noticeable then normal). record your reading, repeat for all cylinders, that is a dry test, after you do all cylinders, then do a wet test, pour a little oil in each cylinder before you test it.
heres a better how-to -
http://www.dsmgrrrl.com/FAQs/compression.htm
they say four strokes, saturn says 10. spec is 180 after 10 strokes.
a leak down test is a little more involved -
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
