Jeep Grand Cherokee 2000 Convertion from Electric Fan to Clutch
santicar21
03-07-2005, 11:44 AM
Team,
I need your help advice, i have a bunch of problems with my Electric Fan, i have replace it already like 3 times, the problem is that the fan get stuck and then I need to push it a little so it can start... and as you know each fan cost like $ 250 dlls..
i was wondering, i do have on the Pulley that goes to the Water Pump theres a Screw Type conector, can i convert it to a CLUTCH AND FAN instead?..
i got a Clutch for the 99 GC and the Fan but i need an extension, cause the blades will hit the other pulleys..
Im buying the wrong stuff?.. What do you recommend? Can the Electric Fan be fixed?..
Thanks for the advice in advance.
Crescent Band
04-25-2005, 06:16 PM
I dont know of any kits to swap from electric to engine. If you have a 4.0 it sounds like it would be a bad idea anyway. Have you tried an aftermarket fan. Still not free at 125 bucks but not 250+. I know its not the answer you were looking for but its worth a look I got mine for 125 on a GC 2000.
