Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 03-03-2005, 10:00 PM   #1
aceeZ71
aceeZ71 Normal reputation
Send a message via AIM to aceeZ71
S10 V8 swap Fuel line Mods
I am doing an engine swap in my 85 S10. I am installing a tpi engine and could use some expert advise on mods for the fuel line on the S10. I would like to flare the lines as the come out of the frame rail in the engine compartment to 37 degrees and install tube nuts and run -6an steel braided lines to the tpi fuel rail using the correct fittings to adapt the steel braid to the gm fittings on the fuel rail. What id like to know is has anyone else tried this an what results did you have and any suggestions you may have to do it a better way. Thanks newbee af member.
aceeZ71 is offline   Reply With Quote
Old 03-04-2005, 06:23 AM   #2
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Re: S10 V8 swap Fuel line Mods
While I'm dumping in a 5.7 to mine, I'm no expert on the fuel line issue. You may wanna check over at www.v8s10.org for that question. Guys there are very knowlegeable on rerouting and lines et-al... Specifically ask Grappler that question because I know he's using braided lines for his fuel in one of his..
rlith is offline   Reply With Quote
Old 03-06-2005, 08:39 AM   #3
aceeZ71
Hey thanks good site thanks for the reference! Aceez71
Bookmarks
Google
Web AF
