Turbo Oil Lines
higdon2k3
03-03-2005, 07:05 PM
Hi I have A '03 Cavalier and I'm having trouble locating oil lines to tie into for my turbo. If you can help me please E-Mail me @ higdon2k3@yahoo.com. thank you i appreciate any info.
-Jayson-
03-03-2005, 10:23 PM
you need to tap the oil pan. . .
zagrot
03-03-2005, 10:58 PM
above the oil level. the farther up you can get it the better. for the oil feed you'll probably find it easiest to put a tee fitting on the oil pressure sensor, but the closer you can locate the oil feed to the oil pump, the better off you will be (oil pressure sensors are usually as far from the oil pump as possible to get the lowset reading available). carefully look the engine over, and remember..... this is supposed to be fun. also, you may want to take this time to consider an oil filter dedicated to the turbo.
higdon2k3
03-04-2005, 11:53 AM
I Plan on Running a oil filter and cooler for the turbo. thanks for the replys. where exactly is the oil pressure sensor? any other info is appreciated.
