Here we go again HELPmovin2stereo 03-03-2005, 05:50 PM Well I have replaced all O2 sensors,because they were giving a rich code and I wanted to improve gas milelage and that was the soul purpose of this mission.Replaced O2 sensors and then it started to run like shit and puff black smoke.So then I replaced The MAF sensor,now problem is worse yet.It runs like a old steam engine chugging and black smoke flying.Here is the deal.When it's cold it runs fine.Once it gets to temp all hell breaks loose.It starts this chugging thing and black smoke starts coming out the exhaust.Get the gas about half way down(or pin it)and the truck gets past this chugging stage.It almost seems as though it has a miss.So I took it for a hell ride and it cleared up.Left it set and black smoke starts to come out again.It almost sounds like it has a miss constantly.I opened the hood and heard the pcv valve rattling.Is this normal?The truck idles rough.Still getting O2 lean code.About to give up here. rlith 03-03-2005, 06:55 PM Have you checked you're injectors? They could be dumping fuel causing the rich condition at this point movin2stereo 03-03-2005, 09:04 PM I have a throttle body,never thought of that though.Can you check it or just replace it?The injector that is.If it was pouring in then why do I get the lean code on banks 1and 2.Then the black smoke because it's runnin to rich. :screwy: rlith 03-03-2005, 10:33 PM I have a throttle body,never thought of that though.Can you check it or just replace it?The injector that is.If it was pouring in then why do I get the lean code on banks 1and 2.Then the black smoke because it's runnin to rich. :screwy: You have a 98, you don't have throttlebody (throttle body stopped being produced in 95) You have CSFI, (all trucks from 96 to current use CSFI) You have a single main injector fired sequentially to 6 lines. More than likely one is stuck open. You need to pull the upper plenum... Fortunatly with your design you can replace an idividual line.. movin2stereo 03-04-2005, 06:24 AM You have a 98, you don't have throttlebody (throttle body stopped being produced in 95) You have CSFI, (all trucks from 96 to current use CSFI) You have a single main injector fired sequentially to 6 lines. More than likely one is stuck open. You need to pull the upper plenum... Fortunatly with your design you can replace an idividual line.. Call me old school but it looks like a carb so to speak.Anyway I 'm gonna take it to a garage and have them figure it out. rlith 03-04-2005, 06:38 AM Definatly not a carb...:D...Let us know how it turns out! movin2stereo 03-04-2005, 04:11 PM O.k. movin2stereo 03-15-2005, 08:38 PM Went to the dealer today.Seems the guy that put the engine in had the timing retarded 12 degrees.Runs good now.I can't wait to see my gas milage now.Very happy at the moment.Wonder what will go next? rlith 03-15-2005, 08:44 PM Went to the dealer today.Seems the guy that put the engine in had the timing retarded 12 degrees.Runs good now.I can't wait to see my gas milage now.Very happy at the moment.Wonder what will go next? How the hell did he manage to do that? The 98 distributor is locked..(at least on the 4.3)...He must have dropped the distributor in a tooth off to the left when he put it back in. Surprised it even started. dmbrisket 51 03-16-2005, 08:12 AM suprised you havnt bent a lifter or anything yet with 12 degrees movin2stereo 03-16-2005, 10:18 PM How the hell did he manage to do that? The 98 distributor is locked..(at least on the 4.3)...He must have dropped the distributor in a tooth off to the left when he put it back in. Surprised it even started. Ya it ran and idled,just horriable on gas.Try 10 miles to a gallon and that was a good day.Although it never seemed like it had the power that it shoud've. movin2stereo 03-16-2005, 10:24 PM suprised you havnt bent a lifter or anything yet with 12 degrees Don't jinx me! :uhoh: dmbrisket 51 03-16-2005, 11:00 PM Don't jinx me! :uhoh: im not, but 2 to 4 degrees is enough if your boosting, let alone a n/a fairly stock (i think) 4.3l BlazerLT 03-17-2005, 05:56 PM Don't jinx me! :uhoh: You best be replacing the plugs if it was running that rich. They are probably really fouled. movin2stereo 03-18-2005, 06:25 AM You best be replacing the plugs if it was running that rich. They are probably really fouled. Never thought of that.The plugs in it are brand new too with not even a 1000 mile on them. :banghead: 16th hippy 03-20-2005, 08:33 AM i know the 98 2.2L uses coil packs with no distributor, but i coulda sworn the 4.3 was the same for that year. rlith 03-20-2005, 09:02 AM no, all 4.3's use distributors movin2stereo 03-20-2005, 12:42 PM no, all 4.3's use distributors Mine does. 16th hippy 03-20-2005, 01:08 PM :banghead: :banghead: Doh! guilty of brain fart. Automotive Network, Inc., Copyright ©2012
