S10 with no battery power
DBSS_Gohan
03-02-2005, 02:27 PM
hiya! Alright, I recently bought a 1988... I think... Chevy S10 truck, And I am trying to get her into restored condition, shes really not in that bad a shape, but I put a battery in, and I've got absolutaly no power. No lights, no ignition, no turnover, nothing. So is it a relay? Or could there be a problem in teh wiring? What should I do to find out and correct this problem?
vtmecheng
03-02-2005, 03:11 PM
I would start by following the battery wires, maybe even just replace them. If nothing gets power that tells you it is probably a problem just after the battery.
J-Ri
03-02-2005, 04:28 PM
Do you know the battery's good? Can you jump start it? Are the terminals bolted on tight?
sector95
03-02-2005, 04:53 PM
Check the battery...is it new or suspect?
Check the battery cables.... especially the ground lead.... make sure it has a clean connection to the chassis. Since you're gonna do a resto, now would be a good time as any to replace the battery cables.
Check the fuse panel...there may be a battery relay fuse that is blown or some other fuse controlling a circuit with the battery relay.
Don't know if they use "fusible links" on the newer vehicles...this is a part of the main power cable designed to melt if the current draw is excessive.
Happy hunting.....
Mike
dmbrisket 51
03-02-2005, 06:52 PM
if top mount, make sure they are tight, same for side, but you can usually tell if its side mount, like missing bolt, i agree with every one, check the fuse block and panel, then get dirty and check ground cable and positive cable
