Re: Re: Honda accord accord 92 cooling system problem
Originally Posted by sohcfreak97
Get A Pressure Tester, Pressurize The Cooling System And Look For Leaks, Its Probably A Heater Hose In The Rear Towards The Bottom, Those Tend To Rot Out And Leak...but Definately Pressure Test It First
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
