paint
lowriderfan187
03-01-2005, 12:49 AM
now that im alomost done sanding does anyone know where i can i get paint---right now i need primer--i just ordered a spray gun off of e-bay and it should arive in a week or so
OverBoardProject
03-01-2005, 01:35 AM
Napa. I believe that they deal in Dupont paint.
If your not happy with how the primer turns out take it to some cheap paint place like Macco for them to spray. Although I'd still supply the paint, and do all the prep work first.
OverBoardProject
03-01-2005, 01:49 AM
Make sure that the primer is an etching, and sealing primer.
Hotrodders has a good body work forum that will probably give you several tips and tricks.
You'll still need to either buy, or rent a proper compressor, with a water filter and get a resporator.
BlazerLT
03-01-2005, 02:42 AM
Prep it and have it masked and ready to go and send it to maaco and have them apray it for cheap.
movin2stereo
03-01-2005, 06:24 AM
NAPA deals with Martin Senour.Use a self etcher primer on bare metal,then a primer surfacer(sand with 320 to knock down the orange peel,then wet sand with 400),then seal,then basecoat,and last but not least clearcoat.If your going the basecoat clearcoat system.
dmbrisket 51
03-01-2005, 06:19 PM
someones going to holler for this, movin2 i know its not the body shop way but its ok, for cheep paint, go to a tractor supply company and get your favoret of 25 different colors, its like 20 bucks a gallon and will come out with a nice shine as long as you get a high gloss paint, then clear coat, sanding between like movin2 said
OverBoardProject
03-01-2005, 07:10 PM
I hate to say this, but your right. That's exactly what I did with my first paint job, and I found it worked great.
It was easier to spray than auto paint, and it still looked good after 3 years of driving. I'd use it on my Blazer if I didn't use it for off road.
The paint that I have for my Blazer is just way more scratch resistant
s10bajadan
03-01-2005, 08:26 PM
check yellow pages for automotive paint supply and
get your primer at the same place you get your paint. they will know what primer is compatible with what paints you want and tell you how to apply it.
Are you repainting the whole car or just parts you repaired or replaced?
If you are repainting the whole car and dont care if its OEM paint you may be able to save some money. I did my blazer over last summer it was $100. per qt not including the activator..(OEM dupont paint) then I still needed clear coat. I ended up to be about $350. when done. oh ya plus the buffing cream and wax another $50. adds up quick.
What do you have for a air compressor?
I would guess and say no less than a 13 gal, 5 hp.(thats what I used) The only moisture filter I used was the type that screw on to the spray gun. I doubled 2 together and had no problems.I drained the compressor inbetween the paint and clear coat. Also make sure you we the floor down with water befor you start spraying..
GoodLuck to ya...
dmbrisket 51
03-01-2005, 09:22 PM
exactly, it adds up quick, for something nice, not show quality, but definetly nice and easy to work with, 20 bucks will get you oil based paint from tsc, or if you want the epoxi style paint its maby 30 bucks for catalyst and binder with pigment (paint and hardener)
movin2stereo
03-01-2005, 09:56 PM
I'm not saying it's wrong, :) but it is in the budget so to speak.
lowriderfan187
03-01-2005, 10:49 PM
aight thanks alot guys when i get all the body work on it done i will post pics of just the primer---holla
lowriderfan187
03-01-2005, 10:50 PM
(still dont know wat color 2 paint it)--interior is red so i was thinking black------the truck used to be red and black but i just want it one color so u guys give me a couple of opinions
dmbrisket 51
03-01-2005, 11:08 PM
black is really the only color that will look good, anything else will clash with the red, that is most likely faded from uv exposure
movin2stereo
03-02-2005, 08:15 PM
black is really the only color that will look good, anything else will clash with the red, that is most likely faded from uv exposureOne problem with black and that is it will show your bodywork(that is if you don't spend some time on it),unless of course you go with flat black.
HanktheHound
03-02-2005, 08:41 PM
I get my paint from O'reilly but I'm not sure if every store carries paint. I use the Nason acrylic enamel because its cheap, looks good, and easy to spray. As for spraying it I would just make sure you have a adequate compressor with a condensor on it. If its your first time spraying I would buy a body work manual and read the primering and painting section. Make sure you start with a clean shop, but I wouldn't suggest wetting the floor down because the evaporation can cause clouding of your paint. The main thing is to take your time if you want a good turnout.
dmbrisket 51
03-02-2005, 10:53 PM
yeah but the problem with flat black, it usually looks like shit
lowriderfan187
03-03-2005, 11:48 PM
HanktheHound--how much does the paint you get at o'rileys costs--cus where im from we have one here
movin2stereo
03-04-2005, 06:26 AM
Agreed!I have seen gloss jobs look like shit more than if they would've painted it flat black. :lol2:
dmbrisket 51
03-04-2005, 09:50 AM
lol yeah, youve got to kind of have the skill and know how to paint, either autobody or something like your house, its not as simple as point and spray and every thing turns out perfect, and like you said, if there is ripple effect in the sheet then your doomed to look like hsit
movin2stereo
03-04-2005, 08:35 PM
Tell that to people who think body work is as easy as sanding and then painting.
ALMB~Nova
03-04-2005, 08:46 PM
you mean you have to sand the bodywork? that explains alot! LOL!!!
dmbrisket 51
03-04-2005, 11:46 PM
nah, sanding is just one of those extra things not really needed, like auto insurence, just a waist of money, hell when i paint, half the time i dont even whipe the dirt off, just spray over it, gives the paint something to stick to :lol2:
ALMB~Nova
03-05-2005, 09:31 AM
I just love the look of stucco on my quarter panel!!!
OverBoardProject
03-05-2005, 06:25 PM
What do you mean spray it? The best paint jobs are always done with rollers, and everybody knows it!
dmbrisket 51
03-06-2005, 01:14 AM
rollers? go to your local paint store, get some satin finish paint and brushes, you will LOVE it
OverBoardProject
03-06-2005, 02:51 AM
what do you think of those water color paints that I used in kindergarden?
dmbrisket 51
03-06-2005, 03:18 AM
doesnt even compair to the finish of fingerpaint (non stain water based kind... of corse)
movin2stereo
03-06-2005, 08:00 AM
Nobody has mentioned spray cans yet.Make sure if you use a spray can,don't mask anything off.So that you paint moldings and glass.I just love those kind of jobs.
OverBoardProject
03-06-2005, 12:19 PM
when my hotrods are ready I'm not even using paint... I'm coloring them with crayons
dmbrisket 51
03-06-2005, 12:31 PM
make sure that when you do this, you color all the same direction, it looks sooo bad when they color in any damn direction they please, and moven2 has a point, spray bombs were ment strictly for point and spray, nothing need be done b4 during or after, its alwse classy to have the tires and stock rims matching the paint on your car/truck/hotrod
OverBoardProject
03-07-2005, 02:07 AM
Check out this web site for Primer / sealer tips
http://www.hotrodders.com/t53742.html
HanktheHound
03-07-2005, 04:55 PM
I think its like 110 for the whole gallon kit i've only bought it in quarts, and that was 60 for the paint and all the thinners and catalyst.
