[quote=c merrill]
Originally Posted by sasmyth
This is the last item on my list so if I get to it "fine". Can an AC mechanic tell if the compressor is good before going through all that? Seems like there ought to be a way.
If not, I'll be wanting to relieve the engine compartment of all that extra gear... after all Convertibles shouldn't need AC![/QU
I have the same compressor problem and was wondering if you found a good way to get rid f the compressor and still turn the alternator?
Nope! I brought it back to NM where it might want AC again, though probably not. My mechanic in Berkeley said the compressor was the easiest/best solution and didn't draw any significant power with the clutch fre-running.
The car is my daughter's (now) so will be repaired only by mechanics so it is less of an issue for me now.
Good luck!
- STeve
