Re: 1997 neon fan problem
a relay can cause intermitent problems. If you can afford it, i'd buy a new one and see if that corrects the problem. If you're brave, you can jump it out with a paper clip during a "not working" time and see if that makes the fan come on. (Unless you have a wiring diagram, you'd need to use a volt meter to see where to jump. you'll want to put a hot on the fan load, which will show up as a ground. hopefully you can look at where the wires feed in to get an idea.)
Of course, i think too if the thermostat were sticking and keeping water from flowing, the temp sensor wouldn't know it needs to come on. You can check that by seeing if the return to the radiator is hot.
I think that would cover all the possibilities (except a faulty fan motor)
Someone correct me if i'm wrong. hope that helps!
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
