88 Mr2 mods..
valgoron
02-28-2005, 01:51 PM
I'm close to buying a 88 mr2 and then a 89 mr2(havent see this one yet, but brother says it has a v6?? or maybe he meant a turbo??? or supercharged?? he said it'll go 150mph.)...well...im getting both for $1000, the 88 runs, the 89 just needs to be finished being put together...i know their worth $1000...but can you mod them to get some power out? like at least 200hp?
attica85
02-28-2005, 04:30 PM
200hp is highly possible but very cost effective. it costs approximately $3000 to get to a safe 170-175 hp so....
your brother probley said supercharged, and expect to spend a couple hundred to get them running well stock.
valgoron
02-28-2005, 05:00 PM
well...we were just going to get one of them running good...just for a driver...put a turbo on..intercooler, cams, stuff that we could...just to get a feel for the mr2..and then the other engine swap a 3gste engine in...
but being as light as it is...it shouldnt need tons of HP to go fast...right?
ac427cpe
02-28-2005, 08:10 PM
the mk1 will get close to 150, the tranny allows it as long as you can get a good long stretch of road...
in 89 they came supercharged as an option, but it is VERY expensive to get a safe 200 hp out of a 4age (supercharged or n/a).
3sgte powered mk1 cars are a blast, but it's quite an involved swap. IMHO, worth every extra hp.
oh yes, and they are FAST.
valgoron
03-02-2005, 02:46 PM
ok..my brother now tells me it has a v6 engines headers......he said the guy who is selling it says itll jump from like 50 to 90 like nothing...soo...v6 headers will work on a 4 banger?
ac427cpe
03-02-2005, 06:43 PM
no... 3 cyl per bank... you'd be missing one exhaust outlet.
valgoron
03-02-2005, 06:51 PM
soo....there is no way a v6 headers can run on it? the guy might have it modified in some freak way
attica85
03-03-2005, 03:17 PM
if you want straight up power without a total engine swap the way to go is to take that sc 4ag and convert it to a turbo.
now you will have to change internals and you'll have to modify but you will be looking at hp gains of over 200 and if youre really serious 330+hp is possible.
im doing this now to my mr2.
valgoron
03-03-2005, 03:44 PM
im def interested...i planned on replacing the stock parts with performance and all..i just need to know what..
ac427cpe
03-03-2005, 04:56 PM
if you custom built a 1.8L 7agte for an mr2 using a 20v head... you'd only be able to pull about 250hp... over 300 is stretching it a bit...
valgoron
03-03-2005, 05:56 PM
is that the stock engine? or a diff one?
ac427cpe
03-03-2005, 06:24 PM
that is custom built for performance
attica85
03-03-2005, 10:12 PM
7agte?
i know it sounds crazy dan, but there are guys that claim 331hp off of a 16valve 4agze seven rib block turbo. i don't know if its a daily driver or strictly track & strip but its been claimed, i mean come on they are toyota blocks.
www.mr2supercharger.com/featuredturbos.html
this site even has some MK1.5s check it out
ac427cpe
03-03-2005, 11:18 PM
if you bump the compression and run unsafe levels of boost w/ the fuel completely leaned out... yes, it's entirely possible. and very expensive because the engine doesn't last too long.
attica85
03-04-2005, 04:30 PM
hmm... probably right, i havent seen either one in person so im going off of what is said.
you would still get alot of yank out of 200hp turbo mk1 though, huh dan, you know how that is.
i have an 85 mk1 4agte which was probably making somewhere around 180hp before i put it "under the knife".
ac427cpe
03-04-2005, 06:57 PM
not too sure what a 200hp turbo mk1 feels like, i can imagine it is a blast....
i do know what a 250hp mk1 feels like though ;)
attica85
03-05-2005, 03:59 AM
oh, come on! squirt some tobasco in my eye won't you..... :crying:.... how i envy you.
by the way whats your time in the 1/4 at 250hp?
ac427cpe
03-05-2005, 12:47 PM
i don't have tires at the moment... it's funny how that works. you work all the bugs out, and run out of tire...
i'll be doing that once all the new upgrades are done
attica85
03-05-2005, 03:49 PM
mmm...i hear you. as soon as drag season started up i burnt a hole in my shifting cable.... it was just awesome :disappoin
ac427cpe
03-05-2005, 11:58 PM
lol! the first time we drove the 1.5 as a 1.5 my dad broke one of the shifter cables!
those aren't fun to change :\
attica85
03-06-2005, 03:44 PM
which set of cables do you use? is it the aw11 cables or the sw20 cables in the 1.5 and do you have heat issues with them?
ac427cpe
03-06-2005, 11:26 PM
the aw11 cables... they're a bit too long, but still work great. i built an additional heat shield to accomodate for the added heat of the turbo.
attica85
03-07-2005, 02:12 AM
when you put the extra heat shield on did it push up against the cable changing the feel of the shifts?
i know the 3sgte is bigger than the 4ag so how does that work and where did you bolt the shield to? it kinda looks like its on the firewall but not sure
ac427cpe
03-07-2005, 12:54 PM
onto the firewall, the cables are just a bit scrunched up... i really don't want to custom make some.
attica85
03-07-2005, 06:04 PM
huh.... so the shield goes over and around in between the manifold and the cable, is it kinda this shape?: |_
attica85
03-07-2005, 06:06 PM
hmmmm.... that didnt work.... i think i got it though
ac427cpe
03-07-2005, 11:32 PM
http://img20.photobucket.com/albums/v60/ac427cpe/mr2/rightside.jpg
you can see it on the back of the cabin in this pic
attica85
03-08-2005, 01:13 AM
hey, thanks dan, looks simple enough, i'll try it and tell you how it goes.
