Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chrysler > Cirrus
Old 02-28-2005, 01:40 PM   #1
dhl
dhl Normal reputation
Red face A604 in limp home mode (41 L/R sol. circuit)
hi.
got a problem with chrysler cirrus 1995 v6 2.5 for months !!!
It goes into LIMP HOME mode (LHM) - P,N,R and 2nd gear only.
It does not matter, if it is cold or hot, raining or not.
Now everything looks great, but the car goes into LHM - sometimes
twice a day. Check Engine still does not light up.
Always only one code is stored in TCM 41 - L/R Solenoid circuit.
- input speed sensor replaced 2 times - no change,
- output speed sensor replaced 3 times - no change,
- TCM replaced 2 times - no change,
- solenoid pack replaced 2 times - no change,
- wires TCM <> Solenoid pack checked 3 times - seem to be ok,
- circuits measured with ohmometer - seem to be ok,
- current through solenoids measured 6~7 A - seem to be ok,
- transmission "rebuilt" - no change,
- torque converter replaced - no change,
Anyone know why 41 (and LHM) comes up ?
dhl
dhl is offline   Reply With Quote
Old 03-16-2009, 04:46 PM   #2
mgs179
mgs179 Normal reputation
Re: A604 in limp home mode (41 L/R sol. circuit)
I had a intermitent limp mode issue with my 1996 Chrysler cirrus....the final fix was to remove and clean out the rectagular transmission solenoid connector and plug with alcohol and seal the hole [that you access the connector removal screw] with a cap and RTV. Problem never returned. I think the main problem is the connector allows moisture to collect inside and disrupts the computers ability to test the tranmission cleanly.
mgs179 is offline   Reply With Quote
Old 09-08-2009, 02:30 PM   #3
stopcar
stopcar Normal reputation
how do you cleaned the connector ? what you use ?
stopcar is offline   Reply With Quote
Bookmarks
Google
Web AF
