'02 With a "Sticky Gas Pedel
sbalgach
02-28-2005, 08:38 AM
HI,
'02 Accord 4 cyl .
When cold, the gas pedel "sticks" at the top.
When going to accelerate there is a noticable "hitch" at the top then everything is OK.
Any help would be appreciated.
Thanks,
STeve
mpumas
02-28-2005, 01:27 PM
Lubrication may be a solution. You need to find if it it is hanging up on the throttle body or cable/linkage. Do some tests and get back to us.
lorunner
02-28-2005, 04:40 PM
You have excessive carbon buildup on the butter fly. Remove the intake tube and clean it with throttle body cleaner. Spray some on a rag and scrub the inside of the throttle body until its all gone. You will see the spots where its black.
Ehscrewdude
02-28-2005, 07:25 PM
Can you use that same cleaner to clean the whole tb? Just like open it and spray it in there and then start the engine???
lorunner
03-01-2005, 05:02 PM
I would do it with the engine running already. Just raise the idle and spray it but not so much that it stalls. Keep it running and spray.
