Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 02-28-2005, 12:16 AM   #1
JTugwell
JTugwell Normal reputation
Question Nos
This is a little off topic, but I have a 01 monte carlo ss and i want to put a 75 shot dry kit on the stock engine and tranny. will this work out or will it just blow something up. the engine is a 3.8 with about 71000k on it. i figured if anybody would know you camaro guys would. thanks for the help. later
JTugwell is offline   Reply With Quote
Old 02-28-2005, 12:42 AM   #2
89IROC&RS
89IROC&RS's Avatar
89IROC&RS Normal reputation
Re: Nos
should be fine. so long as you do the job right, and account for the nessesary increase in fuel to counter the nitrous. I dont know if a timing retard would also be nessesary for that level of spray or not. Although, i dont remember, is the 01 SS the supercharged one or no? if its supercharged, then id say forget about it, if its not, then youre probly ok.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 02-28-2005, 07:33 PM   #3
JTugwell
Re: Nos
no its not supercharged. it turns out that nos has a system dedicated to gm fuel injected engines, so surely they would have the right set up for it(i hope) thanks for the info ill look into the timing retard. thanks for the help. later
Old 03-21-2005, 12:04 PM   #4
demon9766
demon9766 Normal reputation
Send a message via Yahoo to demon9766
Re: Nos
well it will be ok if it is not supercharged,and u won't need to mess with the timing the rule is for every 100hp take out 2 degrees,so if you only spray 75 you will be ok.
demon9766 is offline   Reply With Quote
Old 03-21-2005, 08:55 PM   #5
Rod&Custom
Rod&Custom's Avatar
Rod&Custom Normal reputation
Send a message via Yahoo to Rod&Custom
Take a degree and half!
Rod&Custom is offline   Reply With Quote
Old 03-22-2005, 10:21 AM   #6
Hypsi87
I got your v-8 swingin!!!
Hypsi87's Avatar
Hypsi87 Normal reputation
Send a message via AIM to Hypsi87
How the dry shot works is it sprays the nitrous before the MAF. The extreme cooling effect it has on the MAF "fakes" it into thinking that the car is all of a sudden receiving EXTREMELY cold air. Cold air is more dense so the computer compensates by adding the neccary fuel for the nitrouis. You are basicly relying on your MAF to correct the fuel maps for your nitrous shot. As far at timing retard, your computer will handle that automaticly. Unless you are spaying some ungodly ammounts of nitrous on new GM OBDII systems. The factory spark knock attack and derate maps are agressive enough to handle it. With a 75 shot your ok but I do know if you want to go above 150 shot, a fuel pump and an adjustable fuel pressure regulator is needed.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Hypsi87 is offline   Reply With Quote
Bookmarks
Google
Web AF
