Common problems for a 1993 S-10joblo33 02-27-2005, 10:51 PM Hi, I'm going to test drive a 1993 S-10 tomorrow and I was wondering if there are any common problems I should keep an eye out for. It's $2900 Canadian in a used car lot, so there must be something wrong with it. :P Thanks dmbrisket 51 02-27-2005, 11:02 PM size of moter is really helpful when you need machanical advice lol s10man84 02-27-2005, 11:06 PM dashboard rattles! I had a 93 and the interior rattles would drive me nuts! I guess this is common in those. Other than that, the trucks go forever. joblo33 02-28-2005, 12:29 AM Sorry, I knew I forgot to say something. lol, It's a 4cyl 2wd short box regular cab Thanks for the tip, I'll listen for a rattle, do I have to get it up to highway speeds for it to rattle or was it at city speeds? dmbrisket 51 02-28-2005, 12:34 AM 2.2 or 2.5? lol if you dont know well see what we can do joblo33 02-28-2005, 12:42 AM 2.2 or 2.5? lol if you dont know well see what we can do I can't tell you that cause the truck was locked so I didn't see under the hood yet. I can tell you tomorrow. I just need some obvious things to look out for on the test drive right now. dmbrisket 51 02-28-2005, 01:20 AM well then look for and feel for the normal, pulling, howling, listen for the fuel pump (you should hear it) watch all guages, the oil sending units like to go, so dont let oil pressure worrie you a whole bunch, feel if the tranny slips (assumeing its an automatin and not a std transmission) listen for awkward knocks and test all options, if it has power windows, roll them down, i know its winter, but wait untill summer if they dont work, test the ac, if equiped, if she checks out, she will run for miles upon miles with basic matinence and upkeep, will last longer if you live down south in the no salt territory of the us joblo33 02-28-2005, 01:40 AM Hi, thanks for reminding me how much I forgot to mention about the truck :P I'll just start over: 1993 Chev S-10 4-cyl 5 spd manual 2wd Short box Reg Cab 161,000km on the guage I live in on the coast of British Columbia, Canada. Thanks for the tips. crazycory1 02-28-2005, 09:42 AM 161,000km is a decent amount of use. I would check the common wear items. Ball joints, wheel bearings, steering linkage, brakes and shocks. OverBoardProject 02-28-2005, 11:30 AM If you have a mechanic friend bring him (and your toolbox) with you. We've had a used car lot replacing all the tune-up parts for us and still talked him down $1500.cndn because my mechanic still found a couple of questionable things on the truck. joblo33 02-28-2005, 05:09 PM Thanks, I called my friend who has a car shop a block away from the shop and he said I could bring it over and he'll look at it. OverBoardProject 02-28-2005, 06:47 PM good idea, and good luck ALMB~Nova 02-28-2005, 07:10 PM Check the door pins too as they tend to wear out over time.Have had a few problems with frame rot. (Ive owned about 20 of theseTrucks) MAke sure the frontend is tight. check the cab mounts. Automotive Network, Inc., Copyright ©2012
