97 firebird still missing
Google
Web AF
bucsfan
02-27-2005, 10:30 PM
ok, changed plugs, plug wires, ignition control module,& coil packs. Hooked up the obd2 reader, erased all the codes and started the car up. It ran good for about 10 seconds then it started misfiring again. read the codes and now I have a p0101 code. which is a "maf/vaf" code. It will not stay running. :screwy: You can smell heavy fuel in the exhaust. If anyone has anymore suggestion I am open...... Is there any way to jumper some of the switches to test them let me know. It is acting like one of the sensors is telling it to dump full fuel, but I am not willing to buy every single sensor on the car.
Twizted_3KGT
02-27-2005, 11:38 PM
is your maf sensor plug connected? and/or are the prongs on the connector bent and/or the wires secure? (assuming a 97 has a MAF sensor)
bucsfan
02-28-2005, 12:10 PM
everything looks good on the sensor and the plug......
custom mccannix
03-01-2005, 09:40 PM
disconnect your y-pipe on your exhaust and try to start it if it runs fine like that your cat is bad. the m.a.f. should not be bad remember it can easily be something else downstream causing the problems while the computer thinks it is upstream. good luck
SlackZac
03-03-2005, 04:04 PM
sounds like my problem on my '96. someone suggested the fuel pump. i haven't had a chance to get mine checked yet.
bucsfan
03-07-2005, 01:15 PM
I took out the o2 sensor and cleaned it now it is running great.
Google
Web AF
