Condensation in headlight???G_racer 03-22-2002, 10:00 AM Does anyone know a easy way to get condensation out of a the integra headlights(94+)?? I noticed you can get to the main headlight because of the projector so do i have to take apart the whole headlight lense to get it off or could some one give me some suggestions?:confused: Thanks.:) 96LSIntegraRocket 03-24-2002, 10:41 PM not really sure but..... cant u take the bolts out of plastic brackets then take the head light out then remove the bulbs and finnally shake it out ??? PiNoY GsR RaCeR 03-30-2002, 12:02 AM I don't know for sure if you can fix that problem. I think it's one of the Integra's design flaws. RDEANER 04-08-2002, 01:45 AM get to an air compressor, take the bulbs off and shoot the air inside there. not one of the cans of air because those condense the air and will put more moisture into the lamp than there was before. Or if your a bigshot, just take it off, put them in the oven at the lowest temp and wait for the moisture to evaporate. 91 ls/vtec 202hp THE4TH 04-14-2002, 03:54 PM take the bulb out and take a hair dryer on low... shoot it in the hole where the bulb goes.. do i for a few min, for 2 or 3 days in a row, you should see it go away Automotive Network, Inc., Copyright ©2012
