95 neon need wiring diagrams
gtmarko
02-27-2005, 07:48 PM
hello i`m working on a 1995 dodge neon 2.0, that had a fire in the dash. i need the wiring diagram for the fuse box behind the batt. to the dash, mainly the ing. harness part. the car has manual trans.,tilt,ac,no power windows or locks. thanks again
A97
02-28-2005, 09:27 AM
haynes manual has them about 10 bucks
gtmarko
03-02-2005, 10:23 AM
the haynes book is no good. i need the colors of the wires and harness for the ignition system, the car had a fire!!!!!!!!!
chigowolfs76
03-04-2005, 01:52 PM
autozone.com
free
http://autozone.com/servlet/UiBroker?UseCase=RG001&UserAction=processModel&Parameters=052
gtmarko
03-05-2005, 01:37 PM
autozone.com
free
thanks for the info. but doesn`t cover all the ign. switch wires, there are 8 at the switch in the colum anyone have a factory book on the the ign. switch with the the color codes and where each wires goes?
oldmike
03-09-2005, 05:04 AM
You may not want to do this, but AllData DIY has a subscrption for $24.95 for 1 year that has all the info as detailed as a shop manual.
Fractured1
03-09-2005, 08:26 AM
If you are just looking where the plugs all go with the correct color codes just take a friend and hit up a salvage yard...pen and paper in hand and start looking for all your wires you need to trace...you should know what you need to replace and as you look in that area write it down, remove the plug and move on to the next...if you think you are going to splice each wire you probably will end up with at least one (bad) splice that will drive you crazy after the car goes over a few bumps...so use the factory wires, and plugs and avoid as many splices as you can...good luck
