S70 shuts downBILLYBOBERENO 02-26-2005, 05:14 PM In the morning i let my car run a bit cause its cold here in wisconsin, and it warms up for about 5 min, and i get in and rev it a bit to 2k rpm and it just shuts down on me....wtf?? idk, but can someone help me? also when i go to start it, the battery is always dead, and i charge it upand let the car run for long periods of time, yet when i go to start it ites dead dead dead............. any options would be GREATLY appreciated, thanx.... madfinn 06-01-2005, 07:05 PM how old is the battery, it could be time for a replacement. When the car dies on you, watch the tach, and see if it drops just before the engine dies. If so, it could be your crank sensor, just a guess. Or, when was the last time you cleaned your throttle body, once they get real dirty, you could run into a stalling problem at idle. 99gltTT 10-19-2006, 11:43 PM it could be the crank case or it also may be with ignition antenna, the antenna that tells the engine the proper key is starting it. i had a similar problem, got the antenna replaced, now everything's honky dory. clamjuice 08-14-2009, 12:19 PM you might want to consider not revving the the engine up, I've been told that it can damage the cars that have turbo.:screwy: racerxpl 08-20-2009, 08:45 PM Or your battery is dead by the time you rev it and a lot of cars just will not run with a dead battery in them. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
