My Probe GT makes whistle sound why?
GTjames
02-26-2005, 05:23 PM
I have a 94 ford probe GT and when it is running it makes a whistle sound and the Hight the RPMs the louder the whistle can anyone tell me what going on i dont know if its bad or not but i dont really like it When i took it to get the front axle fixed i had the guy who worked there ride with me and all he said was "do you have a turbo" and i dont so he wasnt to much help if anyone knows what going on in there PLEASE e-mail me even if your not sure you can E-mail me at james_h06@yahoo.com
Ghostcloak
02-26-2005, 11:50 PM
you might either have a turbo..... or if your going really fast as you reach your higher rpms.. you could have an airleak between your windows and the frame.. (nothing a little bit of felt can't fix...) but i seriously doubt you have the airleak thing... Probably a turbo....
I'm sorry to say this... its quite random... but here's my spill cause i've gotta say it...
Anyone who has a car.... and doesn't know if they have a turbo or not in it... should be kicked.... HARD....
lol.... okay okay.. just had to say it... ^_^
blindfoldedhope
02-27-2005, 10:42 AM
I dont think you have a turbo unless you had it installed a turbo wasnt an option on 1993-1997 probes you might have a small leak in your exhaust that some times makes this sound.
If you have a system in your car that is highly amplified it might also cause a whistle due to bad grounding you might be able to hear engine noise...
Ghostcloak
02-27-2005, 01:09 PM
I was assuming he bought it used.... :/
96probegt
02-28-2005, 03:02 PM
check your pcv valve and hose my aunts windstar did that and the pcv hose was leaking
GTjames
02-28-2005, 05:45 PM
can somone telll me what a pcv valve is. were do i find it and where the house on a 24v v6
GTjames
02-28-2005, 05:46 PM
hose not house lol
GTjames
02-28-2005, 05:54 PM
ok i know what one is where can i find it in the 24v v6
RB26DET
03-01-2005, 12:33 AM
have you installed a throttle body spacer lately? I heard that some models have been reported to make a whistling sound when you accelerate...just another thing to check lol hope it narrows your search
a1waytrip
03-01-2005, 01:53 AM
hey my 94 does that to, i thought it was just my ram air intake. lol, i don't see what the problem is though. if it is something, it is something small.
-tom
GTjames
03-07-2005, 11:13 PM
any other things that it could be
93 probe
03-15-2005, 01:29 AM
i would bet that it is ur belts if it does it all the time cause if it is a turbo then it would just be when the turbo kicks in at high rpms but belts r constant. there r a few ways 2 fix it if it is
1. start the car and take a bar of soap and let the belt rub on it so it has some lube.
2. go 2 like napa or some car store and buy a $5.00 bottle of belt squeak stuff
3. pull on the belt when the car is off and if the belt moves kinda a lot then tighten it
oh and ur pcv vlave on the gt is on the front valve cover towards the top right. it is like a little plug, u can pull it out with ur fingers. 2 c if it is bad then pull it and shake it if it rattles it is fine but if it doesnt then u need 2 replace it they r hella cheap $5-10
GClaus17
03-28-2005, 07:01 PM
I have the same high pitched whistle in my probe too and i checked it out and there appears to be a silencer on the exhaust up in the areas of where the pipe bends up towards the engine you might have the same thing on yours.
shawnwilliams
03-29-2005, 10:08 PM
on your hood should say were your pvc is located
CwGrL88Chinny
03-31-2005, 10:06 AM
hey ever thought that it could be coming out of your speakers? Seriously..they higher the RPM's the higher and more annoying the pitch.. Right? I have the same prob. it's not a turbo but I used to joke with people and tell them I did. It could be interference from the engine. Next time it does it smack/kick the passenger side part of the console..seriously, it looks funny and I probally sound stupid, but it's true!!!!!
GTjames
04-05-2005, 03:19 PM
na its not my speakers its somewhere under the hood still havent found it tho
