Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat > '97+
Old 02-26-2005, 03:18 PM   #1
chouxmein
chouxmein Normal reputation
2003 1.8 Liter Turbo Passat Brake Fluid
Just wondering if I needed to replace my brake fluid. I am due for my 40,000 mile check up (just a little over two years old) and my brake fluid is still crystal clear, is replacement necessary?
chouxmein is offline   Reply With Quote
Old 11-06-2005, 06:54 PM   #2
dhoadley
dhoadley Normal reputation
I changed mine at about 2yrs 6 months, which was late according to VW's recommendation. Brake fluid absorbs water and degrades over time. Knowing that German engineering typically doesn't plan for the wide tolerances that we are accustomed to in the USA, I decided to follow the mfg recommendation.
If you're a DIY'er:
I used a Valvoline synthetic brake fluid that exceeds DOT5. The specs were in excess of the Pentosin OEM stuff. The flush took a bit more than 1 qt, so buy two. I also bought a nifty tool for $5 that was basically a tube fitting to go over the bleeder with a check valve at the end. It allowed my to bleed the brakes single-handedly. Don't let the master cylinder go dry!
dhoadley is offline   Reply With Quote
Old 01-09-2006, 02:42 PM   #3
LarryNH914
LarryNH914 Normal reputation
Re: 2003 1.8 Liter Turbo Passat Brake Fluid
If you're a DIY'er:
Hold the Phone!!!!!!
I am under the impression that the 2003 VW Passat take DOT 4! DOT 5 in the US is silicolne based and does not absorb water, but has different properties, like the pedel being mushier.... I am not sure it is safe to substitute DOT 5 for DOT 4 fluid. DOT 5 is not a better DOT 4!
LarryNH914 is offline   Reply With Quote
Old 01-10-2006, 02:29 PM   #4
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
veedubmechanic Normal reputation
Re: Re: 2003 1.8 Liter Turbo Passat Brake Fluid
you can mix dot 4 and 5 but you shouldnt. Its not good due to the chemical properties of each one, they will mix and gel... thats not good
ASE and VW certified. Just here to help
all check light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Bookmarks
Google
Web AF
