I have found it best from lessons learned to start with the basic's first. It may just be your battery or battery connections. On 92's the battery is below the washer fluid holding tank. You will need to unbolt one crossarm, holding tank retaining pins and electrical connection box to access the battery. You can then check the battery connections, pop open the battery caps to check battery acid level, etc. Please remember to put safety first with any battery and electrical activities (eyewear, gloves, etc., etc !).
Of course if you are not handy with tools, and if it is possible to get it running with a jump........ Have a friend give you a jump and follow you to a autozone or other parts place. They can check the battery / charging system free of change and give you some idea of where to start.
