help! drum to disc swapjusg19 03-21-2002, 10:40 PM I'm picking up the whole rear disc from a 90 crx si for my 91 civic hb dx. I need to know if there is anywhere i can get the brake lines i need(either rubber or braided) and what ones i need to get? Also does anyone know what e-brake cable i need since i'm going from drums to discs? does anyone know where i can find out how to put on the rear sway bar? i hear its only 4 bolts. any suggestions are very welcome. thanks!!! EightOhOne 03-21-2002, 11:47 PM You should use the teg e-brake cables....they are a little bit long, but not much at all. As for the brake lines, I THINK the crx lines should work alright, but im not too sure. Are you getting the crx trailing arm as well, or just the disk/parts? Marc-OS 03-22-2002, 12:39 AM Originally posted by jusg19 does anyone know where i can find out how to put on the rear sway bar? i hear its only 4 bolts. Yeah, sway bars are very easy to install. I installed mine in about 5min. it's just 4 bolts, and if you can't find the 4 bolts you shouldn't be driving. 90CRXZCSi 03-22-2002, 09:47 AM Yea if the crx lines wont work for some reason then companies like neuspeed make stainless steel braided lines. EightOhOne 03-22-2002, 07:46 PM oh yeah...the 2 brackets for the teg ebrake lines arent the same as the stock brackets, and need to be "manipulated" a little bit to screw on;) jusg19 03-22-2002, 09:32 PM ok...so its the integra cables i need. but which years? i found how the bar should look being bolted, no need to insult my ignorance :p DarkImportGrey 03-22-2002, 11:42 PM There is a website out there that has the exact parts and instructions on how to do a rear drum-to-disc conversion on a 4G civic. God I wish I still had that link. It comes from the how-to section of "The 4G Civic Site" if you are familiar with it. Sorry I forgot the link, but I figure this might help someone else remember it, or at least the "4G civic page" Ebranste 03-23-2002, 04:12 AM I found a couple sites that might help. try these: http://www.geocities.com/tjsite/rrdisc.htm http://hybrid.honda-perf.org/tech/4g-brakes.html I also found this one, but there doesn't seem to be a link to the actual how-to. http://www.4thgenerationcivic.com/how-to's/How-To's.htm Note that one of these sites actually recommends to swap the 4G front disc's with 5G Civic EX front discs. Larger rotors on the 5G. Hope that helps. Automotive Network, Inc., Copyright ©2012
