caprice transmission question1979Lee 02-25-2005, 08:14 PM Hello all, I was wondering what auto trannies do the 1977-1996 chevy caprices have, th350 - th700R4 - th200R4 - 4L60E-4L80E with the 5.0(305) V-8 or the 5.7 (350) V-8 Engines Only specifically what trannie in what year car? 1977-1981 TH-350 1982-1985 TH-700R4 or the TH-200R4 1986-1989 TH-700R4 or the TH-200R4 1990-1996 4L60E or the 4L80E am I correct? thanks in advance :confused: Morley 02-25-2005, 10:06 PM 1986-1989 TH-700R4 or the TH-200R4 200R4 only, as far as I know. 1979Lee 02-26-2005, 06:51 PM 200R4 only, as far as I know. that was my thought too , i might be buying a 89 caprice with the 305 tbi V-8(5.0)Liter engine and i was hopeing it was the 700R4. thanks for the thought, was hoping it was the TH700R4. does anyone know anything about this tranny?(200R4) thanks dolluper 02-27-2005, 08:51 AM 87 and up to 89 do have 700 's I have a 87 and 89 with the 700 they are heavy duty packages bigger rads ,alt, starter , brakes . axles [size of wheel nuts will tell you] bigger on H/D CD Smalley 02-27-2005, 09:04 AM My 89 and my 86 both have 700s. Morley 02-27-2005, 12:46 PM 87 and up to 89 do have 700 's I have a 87 and 89 with the 700 they are heavy duty packages bigger rads ,alt, starter , brakes . axles [size of wheel nuts will tell you] bigger on H/D Aparently this isn't an indicator either. My caprice wagon has the HD package (12" drums, larger axles, huge radiator etc) and has a 200R4. Morley 02-27-2005, 12:49 PM does anyone know anything about this tranny?(200R4) The 200R4 was the weaker of the 2 trans in stock form...but it can be made as strong as a built 700R4. The 200R4's are the transmissions that were used in the turbo Buicks..Grand National..etc. Some info I found: 81-89 Caprice eng: all Trans: THM200R4 82-93 Caprice eng: 4.3, 5.0, 5.7 Trans: THM700R4 There is a transmission ID guide here: http://hotrodders.com/showthread.php?t=30771 1979Lee 03-01-2005, 05:51 PM [QUOTE=Morley]The 200R4 was the weaker of the 2 trans in stock form...but it can be made as strong as a built 700R4. The 200R4's are the transmissions that were used in the turbo Buicks..Grand National..etc. Some info I found: 81-89 Caprice eng: all Trans: THM200R4 82-93 Caprice eng: 4.3, 5.0, 5.7 Trans: THM700R4 thanks for the info well now i know thanks :smokin: Mercurybarring 07-29-2005, 02:27 AM i have a 93 wagon with the th 200 and through my reserach its the best of the lot becuase it geared lower than both the 300 and the 400 and it overdrive gear is hire better fuel consuption when cruising the only problem is finding aftermarket suupport its also said that the 4L60E and the 4L80E are both modified versions of the th700 1986Z28 07-29-2005, 08:47 AM 90-96 have 700r4s also, i got a 90 and a 92 which both have em HLandin 07-29-2005, 03:21 PM Caprice/Impala with 350-cid V-8 was teamed with the 700R4 in 1983 and retained that until 1990 when it was upgraded to the 4L60 (the 700R4 was renamed 4L60) and retained that until 1994 when it was upgraded to the 4L60E (electronically controlled version of the 4L60). Caprice/Impala with 262-cid V-6 came with 700R4 in 1986 and retained that until the end of the 262-cid after 1990. Caprice with 305-cid V-8 came with 200R4 in 1989 and retained that until 1991 when it received the 4L60. Retained that until 1994 when it was upgraded to the 4L60E. Hope straightens everything out. Cyrix_2k 07-29-2005, 04:04 PM I can confirm the 1989 Caprice w/ 305 came with the 200r4 Automotive Network, Inc., Copyright ©2012
