Re: Re: SL1 won't start; low fuel pressure
Yes this is pretty much what I did. I turned the key on/off several times to get the pressure to build to it's highest point, which was 30 psi. tried to start the car too. still 30 psi.
I have not inspected/test the fuel pressure regulator. So, if it is malfunctioning, it can make the psi seem lower?
If I go to the trouble of taking out the injectors and testing them, I might as well remove the fuel lines front to rear and blow air through the lines to clear out debris.
I really don't see any test procedures for the fuel pressure regulator. It looks like it has an internal diaphram. How should I test it?
Thanks.
