Originally Posted by public
Non-ecotech
Its a bugger. Get the special socket and reach behind the power steering pump, under the intake manifold. Good Luck.
I found one of your other posts about the oil sending unit yesterday..I took off my head and I can see down the back of the block now..
Which is the oil sending unit?
Is it thing above the coil that has a narrow tube and couple electrical plugs coming out of it?..
Also you mentioned something about an ignition coil that could cause a cavalier not to turn over..
where is that located? and what does it look like?
Thanx
