it just died...Roadkill_Ak_47 02-23-2005, 05:03 PM hay guys, so im sitting in this parking lot ideling and the tracker just stoped running it didnt over heat, its not couse i ran outa fuel actualy not 10 minutes ago had i filled up. so any way every thing works exept it just dosnt fire so: i checked for spark, nope i checked for spark directly from the ignition coil, nope Sweet, ill just replace that and be on my way so i did and still nothing so a couple days later i have it towed to a friends house then went to get mom from work, my step dads there so thats cool we went back to my tracker and he suggested i check the ignition fuse or somthin, and it was blown, Sweet it works its ideling just fine... so as i drive away thinkin about the $75 i just wasted over a 10 cent fuse, it died again sure thing it was the fuse DAM IT :banghead: so im swapin fuses out n stuff and they keep blowing and i unno what to do so ... My q-tion is, is the computer or ecu or what ever its called go threw that fuse? ( the fuse closest to the front left tire, i dont have a slot number or any thing its a 15 amp fuse... any help or ideas would be great i wouldnt like to hear the computers messed ... again... ok thanks bye Roadkill_Ak_47 02-24-2005, 11:38 PM wow, 11 people have looked at this and no one has anything to say... that means its a rare problem, and rare problems arnt cheap, dam it Roadkill_Ak_47 02-27-2005, 11:05 PM ok so i have an idea, ill put somthin in the fuse box other then a fuse and fix what ever blows up what do you guys think about that KaotiKCamaro5 03-27-2005, 07:28 PM if the fuse keeps blowing there is obviously an electrical problem. it sounds like you could have a short or possibly a bad ground somewhere in your wiring. Roadkill_Ak_47 05-11-2005, 02:20 AM ya it was a wireing short, along the engine block the wireing support things wore away at the wires then causing it to ground out. Automotive Network, Inc., Copyright ©2012
