98 Expedition CE Lightredrockredneck 02-23-2005, 01:46 AM I have a 1998 Expedition w/ a 4.6L. My check engine light has been coming on alot recently. I took it to autozone and they ran a test on it and it came back to be something wrong w/ the spark plugs or wires. I took it in..they replaced a wire and a plug and it appeared to do a little better but the light still comes on 30 mins after running and flashes the heavier i get into the throttle. I have cleaned the injectors w/ berrymans total system and it still rough idles and lags out when i get heavier on the gas. Any suggestions on what could be wrong? acidburn5377 02-24-2005, 12:39 AM try replacing ALL the plugs and wires and after that try a FULL tune up (ie: air filter, fuel filter, etc.) and if that dont work try the ignition coil. mars619 02-28-2005, 12:34 AM Sometimes if your gas cap isn't placed correctly, it will cause that CE light to come on. redrockredneck 02-28-2005, 01:23 AM i will try all that..the gas cap isnt a issue..i fixed that 2 years ago. Automotive Network, Inc., Copyright ©2012
