wont rev past 3ktmbrrwofl 02-22-2005, 06:08 PM sorry if i'm posting a tired thread but i couldnt find another one... anyway, i've got a 91 ls 5 speed with b18a1, it stalled out on me on my way out of the drive way, the check engine light came on, there was no smoke or anything. i tried restarting it a few times (prolly about 5 mins) and it finally started again. but now it wont rev beyond 3k and when i shift it jerks. i've checked all my fuses and wiring, but found nothing wrong. hope it isnt in the distributor... thanks in advance. whtteg 02-22-2005, 06:10 PM You ECU is in limp mode. Pull the codes and tell us what they are. tmbrrwofl 02-22-2005, 07:43 PM You ECU is in limp mode. Pull the codes and tell us what they are. took it to my local autozone, no luck pulling the codes =/ they dont have the older reader. heres more info: it will idle just fine, but when i want to accelerate, it will stutter (like its missing a spark) then it will all be fine, until i change gears. keep in mind the check engine lite is still on. any suggestions would be appreciated. thx nu-b94teg 02-22-2005, 10:25 PM I'm not sure if you can pull the codes the same way as you would on a 94, but i asked in a previous thread and boostedk20 responded so check it out and see if it helps http://www.automotiveforums.com/vbulletin/showthread.php?t=277620&highlight=cel+codes tmbrrwofl 02-23-2005, 09:10 PM I'm not sure if you can pull the codes the same way as you would on a 94, but i asked in a previous thread and boostedk20 responded so check it out and see if it helps http://www.automotiveforums.com/vbulletin/showthread.php?t=277620&highlight=cel+codes i tried to find the plug, i didnt see anything like that =/ i've changed the distibutor cap and rotor and cleaned my injectors...think it could be a clogged fuel filter? :banghead: b16acura 02-24-2005, 07:39 PM i just did a b16a swap in my 91 integra and i can't wire vtec cause i dont know where to plug the wires on the ecu can any body aswer my question superbluecivicsi 02-24-2005, 11:01 PM i tried to find the plug, i didnt see anything like that =/ i've changed the distibutor cap and rotor and cleaned my injectors...think it could be a clogged fuel filter? :banghead: Your shooting and missing technique to diagnosing your problem is going to waste time and money. the CEL is your answer. Your CEL is on for a reason. it should help you not confuse you. http://honda-tech.com/zerothread?id=468260 http://www.hondata.com/techecucodes.html tmbrrwofl 02-24-2005, 11:13 PM Your shooting and missing technique to diagnosing your problem is going to waste time and money. the CEL is your answer. Your CEL is on for a reason. it should help you not confuse you. http://honda-tech.com/zerothread?id=468260 http://www.hondata.com/techecucodes.html agreed. getting it towed to a shop tomorrow. superbluecivicsi 02-25-2005, 04:47 PM why dont you just retrieve the code yourself with the provided link? unless you are not mechanically inclined to troubleshoot it yourself, just take it to the shop. 94tegRS 02-26-2005, 03:25 AM dont take it to a shop yet, cut yourself a 4 inch peice of wire and strip both ends, find a 2 wire connector undder the dash on the passenger side, cant gaurantee this but i think it wil be a brwon and a green/white wire. I have a 92 GSR and a 90 GS Ill check my wire colors tomorrow and see whats up as far as colors/exact location goes. use the short wire and jump the plug(one end in each terminal of the plug) and turn the key to on and watch it blink. at least try before you pay someone way too much to fix it for you. superbluecivicsi 02-26-2005, 01:15 PM OBD0 vehicles have a led flashing on the ecu. you dont need to jump wires. 94tegRS 02-26-2005, 04:37 PM ok, didnt know that, I knew some did but wasnt sure what years. have only had 1 OBD0 honda and have never had to work on it yet. that sounds even easier then so you shouldnt spend your hard earned money until you at least give it your best try. tmbrrwofl 02-27-2005, 04:04 AM Thanks for the help, but i had to take it to the shop anyway. getting some other work done to it, that i don't have teh tools for. whtteg 02-27-2005, 09:37 PM Hope it doesn't cost a lot. Good luck :bigthumb: sobersgary 03-02-2005, 07:53 PM How did everything go with the car did everything work out ok, what was the problem with it. kornflakes28546 03-02-2005, 09:10 PM How did everything go with the car did everything work out ok, what was the problem with it. haha... three questions in one sentence and not one question mark :lol: tmbrrwofl 03-08-2005, 10:42 PM haha... three questions in one sentence and not one question mark :lol: sorry it took so long to reply, but my distributor went bad. and my radiator spouted a hole. :/ it was only 240 to fix it all =D Automotive Network, Inc., Copyright ©2012
