Spark Timing
mstngcobrasvt98
02-22-2005, 12:39 PM
I'm in the process of finishing a Head Job on a 85 200SX with the I4 dual coil engine. There are 5 marks on the main pully where the timing is set but the paint is gone. What mark is 0 degrees and what is each mark after or before it? The Sticvker under the hood says it should be set to 4 degrees BTDC. Could someone help me out, I'd love to get this car running again. Thanks guys.
slideways...
02-22-2005, 12:59 PM
if its the same as my ka24e then i believe the second mark from the left is 0 degrees if not then just ignore me
mstngcobrasvt98
02-22-2005, 02:02 PM
the plate in the engine bay says CA20(E), I'll try the 2nd mark from left anyways...its gotta be one of them.
D-Bo
02-22-2005, 06:44 PM
couldn't you just try each of them and see what works? i mean the two middle are more likely to be the one you want..
