Gas Tank Vents
fixxxer93
02-21-2005, 08:44 PM
ok, short of it, i have a 95 Blazer. bought it an a week later had a gas leak. took it out and someone who had it burnt the front vent on the gas tank (its a 4 door blazer) the back one is fine. so i got the bright idea to j b weld the vent up. well it ran fine for about two weeks the started cutting out, well parked it then it would just crank, run for two seconds then back fire an die. really bad rough idle, im assuming its where i j b welded the tank, so i oreded a new tank since that one is usless, well now it didnt come with the vents in the new one an can't find them as a replacement part can anyone help, an do you think it might be a diff problem?
BlazerLT
02-21-2005, 09:21 PM
I don't think you got the right tank.
But the problem sounds like the EGR valve has a piece of carbon blocking the pintle open.
Remove, clean and replace the EGR valve along with a new EGR gasket to fix if indeed the valve is blocked open.
ricksza
02-22-2005, 06:09 AM
If the vent was the problem, leaving the gas cap off would be a good test....I don't think that the vent is the problem either. Is it possible that some JB weld fell into the tank and now clogging the pump?
Are there holes in the tank where the valves should be or is it just blank? In either case, time to go back to the dealer.
fixxxer93
02-22-2005, 07:40 PM
im gonna try the egr valve tomarrow. its the right tank, its just like the one thats in it minus the vents...they got to a gas evap i think, they have two hoses that go to them. ive tried the taking the cap off, didnt help, so thanks for the sugestions. thanks for the help, maybe its not the tank, i changed the fuel pump before the tank, an it has a new fuel filter. ill get back an let you know if it helps.
fixxxer93
02-23-2005, 05:33 PM
i have a chilton book on the Blazer, but i can't find the location anywhere. Its a 4.3 liter v6 with the vortec. in the book they don't show it. any idea where its located? an if i do find it, how do you clean it/ service it? an if i dont have a vacume tester....anyway to check it? thanks
rlith
02-24-2005, 06:39 AM
Realize just because the fuel pump is new, doesn't mean it didn't go bad. You may also want to look at replacing the pulsator unit as well.
fixxxer93
02-26-2005, 07:03 PM
i know i shouldnt keep posting but will someone please help?
BlazerLT
02-26-2005, 07:07 PM
Did you even try to find out where the EGR valve was?
fixxxer93
02-27-2005, 07:00 PM
yes......ive changed the one on my 93 chev truck, so i know what an where it is on my truck so i know what to look for. but i have a CHILTON book (for the blazer)that only shows the TBI for the blazer, the book sucks an cant find or really know what the one on the Blazer looks like. its Vortec in the Blazer, an it has no pic of it. so the answer is yes ive looked for it...that why there were so many days between my posts, im sorry if your getting agrevated because im asking......
Magic071
02-28-2005, 01:27 AM
I have an 87 Blazer, but maybe your EGR valve is in the same area. Remove the air cleaner housing assembly...if you have a 4.3L V6 with CPI fuel injection remove the air intake plenum. Detach vaccum line from the EGR valve.....if replacing EGR valve trace the pigtail lead to the main engine wire harness and unplug the electrical connector, then remove switch from the valve. If replacing EDG valve gasket unplug lead, but don't remove switch from valve. (I can list more instructions if need be)....but you should be able to get the jist of everything from this.
ricksza
02-28-2005, 06:01 AM
Look at the front of the engine. Between the alternator and AC compressor is the EGR valve. Has an electrical connector on top (no vacuum hose). Held on by two 10mm bolts.
