Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-21-2005, 08:17 AM   #1
tfmc369
tfmc369 Normal reputation
Question How To Remove Oil Pan On 88 Camry?
i have an 88 camry that has 230k original miles..
and gets a prepetual oil change bi-weekly
i replaced the gasket on the valve cover and that stopped the leaking up there..
but now i have to replace the gasket on the oil pan..
i noticed there is a bar of some kind running across the oils pan..
how do i get the pan off without lifting the engine?..
any help would be greatly appreciated..
tia The FIshman ?;o}
tfmc369 is offline   Reply With Quote
Old 02-22-2005, 10:47 AM   #2
ProMan
ProMan Normal reputation
Re: How To Remove Oil Pan On 88 Camry?
1. There is no gasket for the oil pan. It uses sealant.
2. You have to take off the center support beam and exhaust pipe (A pipe) off to get the oil pan off.
Before you do this, make sure the leaking is from the oil pan, not from the rear main seal or power steering.
ProMan is offline   Reply With Quote
Old 02-22-2005, 11:59 AM   #3
tfmc369
oil pan gasket..
thanx for the info..
it is the pan that is leaking..
i will check again to make sure..
the fishman ?;o}
Bookmarks
Google
Web AF
