99 explorer washer pump fuse keeps blowing?
davidnard
02-20-2005, 05:03 PM
Hi all,
'99 Explorer sport. The washer squirter fuse (7.5) keeps blowing. It will work fine for a couple of hours and the piff , no more squrity :(
Any ideas what to check?
Thanks
Dave
flatire
02-20-2005, 08:23 PM
are you useing the correct fuse?
B33p3r
02-20-2005, 09:38 PM
Wiring, Front Washer Relay, or Washer Pump itself.
flatire
02-20-2005, 09:51 PM
are you saying to check these item's?
punmaster7
02-21-2005, 02:23 PM
My '99 XLT is doing the same thing. If the washer is relayed, then the fuse would only operate the relay, correct? If I'm correct, then I/we should stop there. The fuse I'm popping is in the dash, not under the hood, and it is a 7.5A fuse.
davidnard
02-23-2005, 10:14 PM
so you think it may be the relay?
punmaster7
02-28-2005, 08:36 AM
The problem should be either there or somewhere in between the relay and the switches. The point for setting a relay in the circuit is to isolate the switch from the load and also to provide multiple points of access to one unit. I found where the relay was located. It is in a box mounted to some fender tabs on the right side of the vehicle under the airbox and mass airflow sensor. My Explorer was mashed on that side and may be why mine is blowing. I didn't get inside the box, nor do I know how yet - my owner's manual doesn't make reference to it and time did not allow me to start into that task, but I'll keep you posted when I dig it out. The box mount tabs were broken, and when I rebuilt the car, I wrapped the box with electrical tape :nono: instead of replacing it (which I probably should have done) and zip-strapped it to the mount tabs. It'll be fun getting it back out!
Curt.
davidnard
03-06-2005, 04:38 PM
found the problem, you were right it was the relay, thank you!
dave
punmaster7
03-07-2005, 07:54 AM
That's great, Dave. Did yours fail at any particular time? Mine seems to blow when it's cold to freezing. That's one reason why I haven't worked on mine yet! Maybe next weekend. :lol:
