Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 02-20-2005, 02:33 PM   #1
ian2005
ian2005 Normal reputation
How to change air filter for grand prix
I have a 2000 pontiac grand prix (3.1L) which i bought as a second hand car recently. becasue it reached 10,000 km now, i planed to replace the existing air filter with a new one. As I have heard that changing air filter is very easy, i planed to DIY. However, it seemed not that easy after I opened the hood. The filter housing is not horizontal as what it is shown on the general instruction of installation. The housing is actually vertical. I followed my owner's manual, loosing the two clips, pushing the filter cover housing toward the engine but not succeed. It is really hard to push the housing. I suspect what I did may be wrong. I am wondering whether anybody here did this before and could give me a hint. Thanks a lot.
ian2005 is offline   Reply With Quote
Old 02-20-2005, 05:15 PM   #2
jon95se
jon95se Normal reputation
Re: How to change air filter for grand prix
this is an easy one.
the air intake tube... take it out. take out the black tube near the throttle body. and unplug the Mass airflow sensor.
next, loosen up the two clamps on either end of the tube. pull the tube off the throttle body and off the air box.
now you can easily take the airbox cover off and replace the filter.
jon95se is offline   Reply With Quote
Old 02-21-2005, 07:44 PM   #3
ian2005
Re: Re: How to change air filter for grand prix
so it is different with the procedure on owner's manual. actually, i am really confused with that instruction. it tells that i shall loose the two clips on top the housing and lift the filter cover tabs out of the housing which i don't understand. then push the filter cover housing toward the engine compressing the duct covolutes. however, i tried it doesn't work. i am wondering there are some other clips instead of the two on top. do you know? i would like to follow your way but not sure about the sensor. please advice. thanks a lot.
Old 02-22-2005, 07:17 AM   #4
jon95se
just unplug everything from the duct covolutes. the little black breather tube, the wire harness from the sensor. should be a total of three things you unplug and then remove the convolute. then you will be able to unclip the two clips and push the filter cover housing out and off from the filter.
Bookmarks
Google
Web AF
