Adjusting tranny BandsSinful 02-20-2005, 11:07 AM Can anyone tell me how to adjust my tranny bands during a fluid/filter change on an 01 ram 1500, 360 Spice137 02-22-2005, 11:36 AM Per the Hanes Repair Manual: The front adjusting band is on the left side of the transmission. Loosen the adjusting screw locknut approximately 5 turns, then loosen the adjusting screw a few turns. Tighten the adjusting screw to 72 in-lbs then back it off 2 7/8 turn (for 46RE trans) or 1 7/8 turn (for 47RE trans). Then hold the adjusting screw from turning and tighten the locknut to 30 ft-lbs. For the rear band, remove the pan. Loosen the adjusting screw locknut four turns. Tighten the adjusting screw to 72 in-lbs, then back it off 2 turns (for 46RE) or 3 turns (for 47RE). Then tighten the locknut to 25 ft-lbs. Automotive Network, Inc., Copyright ©2012
