Black Smoke Sr20detMayday0017 02-20-2005, 10:31 AM My Sr20det is smoking when reved, the guy who did the wire harness did a shitty job I am going to pull it and redo it myself so I will know it is done right. Any other suggestions? Compression looks good. I'm thinking Intercooler leak, bad MAF, or wireing problem. Any other suggestions of things to check would be appricated. TatII 02-20-2005, 11:33 AM your just running really rich. check 02 sensor, check for vacuum leaks, or a bad MAF, all these can cause you to run rich. also check if hte BOV is leaking. R.W.240 02-20-2005, 04:35 PM your just running really rich. check 02 sensor, check for vacuum leaks, or a bad MAF, all these can cause you to run rich. also check if hte BOV is leaking. Exactly. nissanfanatic 02-20-2005, 05:01 PM Where in terms of throttle position percentage wise? Automotive Network, Inc., Copyright ©2012
