2001 taurus ses heater problem
smily157
02-19-2005, 01:34 PM
I have had this car for about a month and last night, i started the car and got the heat up, but then it went cold. I have the heat set all the way up, and sometimes it blows hot air, and sometimes it goes cold. It does both intermintantly, anyone have suggestions? Is it the thermostat or something else? Thanks
sfontain
02-19-2005, 05:12 PM
How many miles, and when have you had your coolant changed?
If it's not the thermostat, and if your heater core is plugged it might be worthwhile to try to backflush your system, and if that doesn't work then you might be looking at a mighty expensive heater core replacement.
TomV
02-21-2005, 01:17 PM
You should not have to go too far back in time on this message board to see what others with heater problems have done to isolate and fix this type of problem.
smily157
02-23-2005, 08:40 AM
I just bought the car 3 weeks ago, i do not know the last time the anything was changed except the oil which i just did. The car has 69k miles
smily157
02-23-2005, 09:09 PM
Problem Solved, I flushed the radiator and put in fresh coolant. Thanks
