Re: 93 k1500, wants to stall when cold
Have you cleaned the fuel injectors? Try a bottle of Sea Foam or another GOOD cleaner.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
'86 3/4 ton Silverado
350 V8, 4x4, 4" lift, 1 ton axles swapped, converted to 4 wheel disc
35" BFG Mud Terrain T/As
Shortened to 109.5" wheelbase for those tight trails
http://www.boycottpepsico.com/default.aspx
You see "Fresh oil, loose gravel"; I see "Free undercoating"
