my car wont run93n240sx 02-18-2005, 08:59 PM i have a 93 240sx and when i turn the key in any position(acc,on,&start) nothing happens, fuel pump won't even come on and no dash lights either. and i have a good battery no blown fuses in fuse box and all good relays the only thing that works is my head lights and hazards. nothing to the electrical system has been done for any wires to be cut. it hasn't been sitting for any more than 2 days. monooxide 02-18-2005, 09:10 PM I would assume Dead battery then... logik23 02-18-2005, 09:37 PM i have a good battery I would assume Dead battery then... ....... monooxide 02-18-2005, 09:37 PM Heres another thing i found...for maybe a solution... Plugs by Battery may be wired incorrectly, they plug in but won't work without rewiring. Pump should run for 3 seconds then stop if flywheel not moving. nissanfanatic 02-18-2005, 09:54 PM Nothing works when the key is on the "on" position? Or is it only when you attempt to start the car? LaYzIeNoY 02-21-2005, 11:48 AM maybe the wires to the key are messed up i know that happened to my friends trunk you said the lights still work, so i doubt the battery D-Bo 02-21-2005, 12:47 PM has it been sitting for a while? when did you drive it last? is it a problem that just happened one day? did you do any work on the electrical system? ignition?? anything else that may have cut a wire?? more details Automotive Network, Inc., Copyright ©2012
