02 knocking
Google
Web AF
dave4887
02-18-2005, 08:42 PM
I have a 02 G.A has been using more antifreeze than what I consider normal (ADDING EVERY 3 WEEKS OR SO) now I am getting a bad knocking sound like a lifter or something every so often after the car sets overnight not every time and only till it warms up or even is put in gear and moved sometimes oil is not milky and is changed every 3000miles
Ridenour
02-18-2005, 10:10 PM
It sounds like you could have a bad LIM gasket.
They knocking is most likely the typical 3.4 lifter sound - our pnuematic lifters take a while to get the oil up to em when you first start up.
The anti-freeze leak is most likely an external LIM leak. Your oil would not be milky if it was an external leak. Check the area underneath your throttle body. This is a typical area to have an external leak.
dave4887
02-19-2005, 05:03 PM
thanks, although the lifter noise I was pretty extreme,not the norm lifter chatter from a cold engine.but at least I have something to check now
Ridenour
02-19-2005, 10:54 PM
No problem.
Well maybe actually it was even piston slap.
Google
Web AF
