Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 02-18-2005, 06:29 PM   #1
90tegblackwidow
90tegblackwidow Normal reputation
Question Help with OBD0 OBD1, OBD2?
I don't know very much about acura engines, I see people refering to these codes OBD0, OBD1, OBD2, can somebody tell me what they mean?
Thank you, I really appreciate the help!
90tegblackwidow is offline   Reply With Quote
Old 02-18-2005, 07:09 PM   #2
blacksol28
blacksol28 Normal reputation
Send a message via AIM to blacksol28
OBD stands for On Board Diagnostics. It is basicaly the emissions control for your car. the higher the OBD number the more sifisticated the emisions control system. I dont have a real detailed knowledge on the subject but it you do a search you could fill in the blanks.
blacksol28 is offline   Reply With Quote
Old 02-18-2005, 07:14 PM   #3
civickiller
civickiller Normal reputation
Send a message via AIM to civickiller
Re: Help with OBD0 OBD1, OBD2?
obd0 or pre obd is 91 and later, obd1 is 92-95, and obd2 is 96 and up
Team Lonely Drivers
civickiller is offline   Reply With Quote
Old 02-18-2005, 08:20 PM   #4
90tegblackwidow
Thanks for the info. But can I put an OBD1 or OBD2 into my car which is a 90 integra(OBD0)?
Old 02-18-2005, 08:30 PM   #5
blacksol28
yes you can put a newer OBD in your car. You can't leagaly put an older OBD in your car but you are OBD 0 so its not something you need to worry about. I've never done a swap myself so im not sure how hard it is to wire it up but from what i have been told its not too bad.
Old 02-18-2005, 08:57 PM   #6
crv-tec
crv-tec Normal reputation
Re: Re: Help with OBD0 OBD1, OBD2?
Does that hold true for all hondas/acuras?
'nuff said
crv-tec is offline   Reply With Quote
Old 02-18-2005, 09:25 PM   #7
90tegblackwidow
Do they make OBD0 to 0BD2 Conversion harnesses? Im looking for one and i can't seem to find one. I'm planning on putting 98-01 LS engine in my 90 LS.
Old 02-18-2005, 09:58 PM   #8
civickiller
crvtec, im not 100% sure but i know thats accurate for civics and integras and preludes.
i dont think they do make obd0 to obd2 because nobody wants to go obd2. if i was you, i would get a 4 wire obd1 o2 sensor and just swap to obd1 with that newer ls motor
Team Lonely Drivers
Old 02-19-2005, 07:11 PM   #9
90tegblackwidow
Oh so I can use an OBD1 harness and hook it up to the (OBD2) 98-01 LS engine ?
Old 02-19-2005, 10:45 PM   #10
civickiller
no but what you have to do is get a obd0 to obd1 conversion harness so now you have a obd1 ecu.
now just splice the obd2 plugs for the injectors and dist into you harness. because your obd1 ecu will run obd2 injectors and dist. the only thing you need is a 4 wire o2 sensor. also if you plan on using the obd2 injectors you need to rewire your car to run those high impedance injectors
Team Lonely Drivers
Bookmarks
Google
Web AF
