1993 Dodge Caravan Spark Plugsbjbbj 02-17-2005, 09:22 PM We have a 93 Dodge Caravan 3.3 liter, V6, fuel injected and we want to change the spark plugs, but we can't get to the three in the back of the motor. How would we go about getting to them when we can't even see them?????? Help GTP Dad 02-18-2005, 06:43 AM Two ways, put the van on a lift so you can reach them from underneath or remove the phlenum so you can reach them from the top. bjbbj 02-18-2005, 08:25 AM Two ways, put the van on a lift so you can reach them from underneath or remove the phlenum so you can reach them from the top. Thank you for the help. I will have to try option B, I don't have a lift wish I did it would probably be less of a hassel. theFREAKnasty82 02-18-2005, 01:37 PM just be advised that if you take the plenum off, you'll have to replace the gasket between it the other half of the intake manifold. bjbbj 02-19-2005, 09:46 AM just be advised that if you take the plenum off, you'll have to replace the gasket between it the other half of the intake manifold. Thanks for the tip. I would have never even thought of that. HiRez_L 02-21-2005, 10:44 AM And as long as you have the plenum off, might as well port and polish it, right? :D http://robskorner.org/faqs/3litrefaqs/plenum/plenum.html Automotive Network, Inc., Copyright ©2012
