Gauges not working/No BUS 2001 Ram 5.2
challenger74
02-17-2005, 03:07 AM
My check engine light was on (code PO442/P0455). Well I replaced my gas cap and that didnt fix it. So I check under the hood to look at the hoses where the canister is. I tighten the cap where it says Evap 1lb pressure.....OK, I go to start the truck now and the gauges don't work and the mileage area says NO BUS...
Anybody know what the problem is??
theFREAKnasty82
02-17-2005, 05:29 AM
sounds like your instrument cluster has lost the communication between it and the BCM or PCM. If it's intermittent, check the connection behind the cluster to see if there's a loose connection or crap behind it.
challenger74
02-18-2005, 11:43 PM
Took it to the dealer today. They told me I need a new gauge cluster. 800 bucks....damn
theFREAKnasty82
02-19-2005, 05:44 AM
go search on ebay or a junkyard; you'll find one for a lot cheaper than $800; usually they'll run $150 to $200.
challenger74
02-20-2005, 12:57 AM
Actually the part costs 500 and the rest is installation...
whitlock
02-20-2005, 11:35 AM
Anybody know what the problem is??Did u find an answer to your problem......it just happened to me two weeks ago...trk runs great but I still have NO BUS on the odometer...& all dials are zeroed out not working....HELP ????
challenger74
02-20-2005, 05:10 PM
Yeah, the dealership told me I need a new cluster (ie: Gauges).
whitlock
02-26-2005, 03:47 PM
What have u decided ??? Gonna get the cluster replaced ?? Continued part of my story is a friend of mine replaced my cluster w/his from another trk (that was working)....result: it zeroed out his gauges and caused his "cluster" to register "no bus" in my truck....he also went to put it back in his trk.....Zap !!....same thing...no bus on his trk now .............#@$%$^%$^&^$@@X!!!!!!.....
Thanx fer responding.........
challenger74
02-26-2005, 11:27 PM
The cluster was replaced..... Still kinda upset..I only have 44k miles on my truck. C'mon, it shouldn't go bad.
whitlock
03-01-2005, 06:07 PM
All is operational ???? Did the warranty cover any costs???( my trk has no warranty) What did it cost u ???? I am in Miami, what part of the country are u ??? Thanx...........
challenger74
03-01-2005, 09:03 PM
I live in Miami too. I took it to Dadeland Dodge. Yeah, everything is operational. No the gauges were not under warranty. One problem though... Before the guages went bad on me my check engine light was on(code P0455 & P0442). Well I told them that and they did say that is was a sensor which was under warranty. About 5 days later the check engine light came back on. I check the code and it's the same one. Now i have to take it back in.
