Brake Warning Light
3blonds
02-16-2005, 08:02 PM
I have a 2001 Town & Country. A red brake warning light stays on. The brakes work fine and the parking brake works perfect. A computer analysis indicates it is the parking brake. Can someone tell me the fix so I can pass the vehicle inspection?
Thanks
yogi_123rd
02-16-2005, 08:46 PM
When you use your parking brake, there is usually a switch on the arm of the foot level that sets the braking brake light in use. If the pedal doesn't return all the way when you release the parking brake, the cable may have slack in it and just in need of adjustment. Light will stays on for this reason.
To see if this is the case, try releasing the parking brake, and at the same time, pulling the parking brake lever up to the maximum position it will go. See if the light goes off.
zulman
02-16-2005, 09:13 PM
Thanks
Could also be the switch itself stuck in the ON position. Locate the switch and play with it to see if it makes a difference
3blonds
02-16-2005, 11:36 PM
Thanks, I'll try your ideas tomorrow and let you know the results..
theFREAKnasty82
02-16-2005, 11:59 PM
another thing to check is make sure your brake fluid is full; it'll light up that warning light on your dash as well.
HiRez_L
02-17-2005, 10:53 AM
Mine always sticks on unless I pull up on the e-brake pedal while pulling the release.
