1998 Grand Caravanfogman62 02-16-2005, 07:12 PM How do you get the right front turn signal bulb out to replace it? I removed several screws & still couldn't get the lens cover off to change it from the outside,& in no way could I get my hand in the small cut-out behind bulb in the engine compartment. Big Dan58 02-17-2005, 01:09 AM If you look at the fender well, there is a round part that you can turn. It's actually a cover that allows access to the bulbs. It's bitch to get to but it works. rjmead86 02-17-2005, 04:38 PM I found that in my 96 Caravan (http://rickreport.blogspot.com/2005/01/here-is-car-ive-been-driving-for-last.html) the little access doors wouldn't open, so I unscrewed about 5 screws inside the wheel housing and was able to reach through that way. It helps to use a flashlight so you can see what you are reaching for. Automotive Network, Inc., Copyright ©2012
